9
99CSVT Offline OP
This is for a buddy of mine. He has a '93 Escort, and the wipers (front and rear), along with the heater blower stopped working at the same time. i checked all fuses, they are fine. I checked to see if there was power going to the culprit fuses, and there isn't. Anybody have any ideas of what this could be? Any ideas are appreciated!
Sean
'99 Silver SVT Contour (2000 miles since June, now needs new front brakes and bearings) '98 CBR900RR Again (Put away for the winter)
Had a simular problem with my Contour. It was a fuse bolted (under a plactic cover)on the engine, back by the fire wall.
9
99CSVT Offline OP
The only bolted in fuse is the main mega fuse. Everything else are relays. I talked to him some more, and he said it was an intermittant problem before (turning controls on and off a few times to get it to work), but that would indicate a switch. No it isn't even getting power. I'm totally dumbfounded (it's not the first time). Thanks for the tip, any more would be appreciated!
Sean
