mmarfan Offline OP
This topic was kinda accadentally brought up in another topic, but it's a good thought. What kinda preformance gains (if any) would someone get if they do this? And what about if you get a turbo or S/C, and put the SVT computer in there (and of course the custom chip that comes with it), would there be any increase in power? I know the timing's higher (because you guys gotta run 91 octain), so would someone have to run 91 octain in there after this "mod"??
And the last important thing, is would it screw everything up???
99 Ford Contour SE Sport
Manual V6
SVT front/ rear bumper /w Aussie grille
Jet black
Premier DEH-P740MP head unit
matrix display, plays Mp3s!!
800 watt Kenwood amp
2 12" Polk Audio subs
Blue "euro" headlights
Eibach Pro-Kit springs
17" Enkei RS-5
White Indiglow gages
Bad idea....some crucial engine components are different and who knows what might happen.
Dan Parmelee
1999 Acura Integra SiR-G coupe
"I heard Affleck was the bomb in Phantoms"
"Word, bitch! Phantoms like a muhfuka"
F
F
I don't think there will be any gains, but if you make the effort, more power to ya'
The SVT has 19# injectors, while the SE has 17#... that could be a problem right there. Also, the reason the SVT needs 91 octane could be timing, but it could also be increased compression, or any combination of the two.
2000 Mercury Cougar V6 ATX. 16.0@87MPH, 155.0 FWHP
Not a good idea. Get a chip. Cheaper, easier, and more likely to produce good results.
2000 SVT #674 - Check it out!
if you did get the #19 injectors and the SVT cams would it be safe to change out the computer or would I have to do more.
mmarfan Offline OP
Originally posted by ScottK:
Well, Bill Jenkins tried it a long while back, but due to the PATS system it was a no go (literally).
What is the PATS system??
Manual V6
Jet black
17" Enkei RS-5
mmarfan Offline OP
Oh, so his key wouldn't even work...
What about if I put a 3L in there and do the SVT computer, and reset it for new keys (through Ford or someone) would that have any increase in power?
Manual V6
Jet black
17" Enkei RS-5
