#1498093 02/07/06 09:48 PM
ty976 Offline OP
Help...Help...
My 96 Contour had a slight miss and hesitation at idle and acceleration. I was checking the spark plugs when I pulled #1 the electrode (porcelan) was broken . Some of the broken pieces got into the cylinder so I rigged a small vacuum hose to get out what I could. I then turned it over a few times without a plug to blow out any debris. After I installed new plugs it acts like it's not getting fire and thumps like it's trying but will not start. Could this engine have jumped timing?
96
2.0
133,000mls
Any help appreciated
Hope you did get all the debris out of the cylinder.
Are you getting spark?
Are the wires on in the right order?
Plugs gapped to .050"?
Do you have fuel?
Check all the little things that can go wrong first, then post back with your findings.
95 Contour GL. Bought new. BAT Sway Bars/Pioneer CD/Koni Rear Struts/Mobil Fluids. Looking for 15" alloy rims-PM me. 180,500km's so far.
ty976 Offline OP
I have fire, fuel and correct firing order and gap.
Firing order,
1234
13
42
I have turned it over to a mechanic friend. He says that it runs now as long as he's pressing the accelerator but as soon as he lets go it dies. He's having trouble with this one and he's pretty good.
Check the TPS sensor. When he holds his foot to the floor does it red line the rpm's or barely run?
i just posted a thread about the same problem it turned out to be my ignition coil and my ignition coil harness.... also i pour a bit of oil down each cylinder and press the gas pedal all the way down and the car started...... SO BIG JIM WAS RIGHT
