#1497294 02/06/06 11:17 PM
Ok my WR headers are being delivered tommrow and plan ok having them in tommrow night sometime.Still haven't found a three bolt flange close by and dont have the time to get one shipped.Just wondering if a local exhaust shop would have them or if they can make one to fit.If they can't make/have one I will stick the factory Y pipe in till I get one but there won't be any flex in the exhaust seeing how I broke the bolts in my factory Y and will have to use regular bolts.Will using the regular Y with regular bolts cause to much stress?Whats the flow difference between a stock(unoptimized) Y and the Weapon R.
#1497295 02/06/06 11:19 PM
i didnt think the stock Y bolted to the weapon R's. But yea, Warmonger has a 3-bolt flange, and Trubendz has them. Maybe someone with some more knowledge(Stazi) can shed some light.
Originally posted by MxRacer:
Originally posted by RawBurt:
much like your weiner.
#1497296 02/06/06 11:21 PM
Yea I sent a PM to war and if they can't make one then I will get his.Just sorrta need car back on the road asap and didn't want to wait for shipping time>
#1497297 02/07/06 01:17 AM
you could always just hold off doing the header install for a week...
#1497298 02/07/06 02:02 AM
To do it right, an extra week is worth the wait. One of your local shops should have one in stock to match up to the 3 bolt Y. Otherwise, get QUOTES for the work & have the winning bidder order the part. You may also need them to install an O2 bung.
#1497299 02/07/06 07:35 AM
E
E
doesn't it take like 2 weeks to get the rear manifold out anyways?
95 SE MTX svt exhaust intake deer killer
#1497300 02/07/06 08:41 AM
Just need the car back on the road ASAP other wise I wouldn't mind the wait.Worked on it for 2 1/2 hours got all done except the 3 bolt on the top of rear manifold,didn't have enough extensions.
#1497301 02/07/06 04:11 PM
2 days.
#1497302 02/07/06 09:14 PM
W
W
Well, DON'T fail to put those three nuts on the top of the rear! Make sure you use all 6 nuts and secure the headers good or you will have exhaust leaks up the ass and probably incurr driveability issues.
As far as the 3-bolt flange, I've got it and as soon as you decide you want it, and I receive payment then I'll priority mail it to you and you'll get it in probably two days.
#1497303 02/08/06 04:28 PM
You could just cut the flange off and have a shop weld the other section of pipe onto it. You have disconnects before and after anyway. There really isn't a need for that disconnect anyway.
1999 3.0L Cougar: 220fwhp and 200tq 2003 VW Passat W8 with 4 Motion AWD http://www.cardomain.com/ride/300644 PM for intrest in 3L SVT Contours, 3L swaps into your current car, Prepped 3L engines, or anything 3L related.
