Yes, scan for CEL codes and post. Does it crank but does not start or does it not crank at all? When you turn ignition to "on", does the CEL light up (to determine if power is going to the PCM-brain)? In addition, check if Fuse 4 Ignition (or 6 in some years) is missing from the Power Distribution Box next to the battery.
