Posts: 69 |
Originally posted by RRT_SVT: and the temperature don't say normal mine says and is a svt 98 i think maybe is a aftermarket gauges or something like that
99-00 did not spell out normal in the temp area. I know they aren't aftermarket gauges because there was a ford build sticker on the back of the cluster.
'99 SVT Contour
Tropic Green
Stock
Posts: 69 |
Originally posted by todras: I really wonder if you can add the traction control switch to make it functional like one other person has found. You might have a rare one. Not that traction control is a good thing. If you don't have I believe it's active all the time and you can't turn it off unless you have a switch. Take it out on a dirt road and see if the traction control kicks in when you floor it.
We had some snow last night, and I spun the tires. No traction control from what I can tell.
'99 SVT Contour
Tropic Green
Stock
Posts: 4,141 |
That is different than ANY of the 3 99 clusters i've had in my hands.
Totaled 02/12/06
Born 3/24/99 Reborn 3/18/06
Posts: 5,345 |
I wonder if it could be a Mondeo instrument panel cluster.
1996 V6 ATX 96K miles
Posts: 4,141 |
Originally posted by Tony2005: I wonder if it could be a Mondeo instrument panel cluster.
If it was it would be in KPH and wouldn't have SVT on the tach.
Totaled 02/12/06
Posts: 3,816 |
Originally posted by pole120: Originally posted by Tony2005: I wonder if it could be a Mondeo instrument panel cluster.
I haven't seen a Mondeo's panel, but all the other's idiot lights here don't have words. They are all pictoral.
So no "BRAKE", "ABS", "CHECK ENGINE", "OD OFF", etc.
Posts: 69 |
Well I just got off the phone with Ford Customer Service, and they won't offer assistance....big surprise. I first went to the dealer and they told me what I already know....the car is out of warranty. I then called the SVT hotline and they said they have never heard of this issue. I know that the car is a '99 and it's out of warranty, but how could this get past factory inspection without the check engine light being there? The previous owner claimed he never noticed it, but it's going to be a problem for me when I get the car emissions tested. HELP...anyone have any contacts inside of Ford??????
'99 SVT Contour
Tropic Green
Stock
Posts: 5,345 |
At this point, I would remove the instrument cluster panel lens and cover assembly and reinstall the panel. Then turn ignition to on and then to start. Make a note of what lights come on and what come off (at each position) and try and map the position to the shop manual and maybe some other SVT owners can post pictures of their instrument panel cluster with the idiot lights on for you to compare. Good luck. http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1b/d0/ef/0900823d801bd0ef.jsp
Posts: 69 |
Originally posted by Tony2005: At this point, I would remove the instrument cluster panel lens and cover assembly and reinstall the panel. Then turn ignition to on and then to start. Make a note of what lights come on and what come off (at each position) and try and map the position to the shop manual and maybe some other SVT owners can post pictures of their instrument panel cluster with the idiot lights on for you to compare. Good luck.
Thanks for the info, but that's really what I did already. The top two pictures are with all lower bulbs taken out and light shining behind the cluster. The next picture is the diagram of where the indicators are supposed to be. The last two is with the key to the 'on' position while the dash is doing it's selftest.
'99 SVT Contour
Tropic Green
Stock
