There are 2 holes in the pulley. I took a tap and put some threads in them both. Next, screw 2 bolts in. Put a pry bar in between the bolts to hold the pulley in place. You need a 19mm? socket for the center bolt on the pulley. It shouldn't be that tight. Mine came off no sweat!
