#112581 01/19/02 12:56 AM
pretty soon i am gonna get a shoshop y pipe. my question is which pipe i should get. either the offroad, then adding an aftermarket cat, or the high flow one? thanks
Tom
1998.5 T-Red SVT Contour
#6044 of 6535
K&N (Thanks Paul)
tcomps@att.net
Aim: Paintball4life69
*Looking to sell svt to get mustang*
#112582 01/19/02 01:02 AM
I
I
I'm not sure but I don't think you can add a cat to the offroad pipe. If you can it will probably cost more than the hi flow one. :rolleyes:
98 svt #3967/6535
BOD 10/13/97
itg air filter
air inlet pipe
south country strut tower brace
A pillar gauge pod w/autometer Volts, Oil Pressure. and A/F Ratio
Replaced resonator w/Dynomax Bullet
#112583 01/19/02 02:14 AM
There 4 diiferent kinds of pipes:
1. Alum off road (no cats)
2. Alum off road (with cats)
3. Steel off road (no cats)
4. Steel off road (with cats)
The first one is the cheapest and the 4th one is the most expensive. I think it goes for over $200 bucks. I went with the alum no cats with a borla cat-back system. There is very little drone in my car. Depending on where you live and how ong you plan on having your car is also a decision on wich pipe to get. Here in MI, I will probably get 3-4 years before the pipe starts rusting. I should have gone with the steel, since the borla is stainless steel. Maybe next year I will upgrade to the steel.
14.72@ 92.6 mph
www.modularV8.com
"CLUTCH KILLER" and also recently known as the DRIVETRAIN KILLER
#112584 01/20/02 07:12 AM
Aluminum off road.
You can always put a cat in it later if needed/wanted for less than the difference now.
2000 SVT #674 - Check it out!
#112585 01/20/02 07:54 PM
NONE eek
Read my post, 15.4 @89.......when you get the chance in Performance, you'll understand why. I think I should send the damn Y back to them for false advertisement, claiming 10hp @wheels only to actually see your car get slower, sheeeeezzzz mad
Performance Xpress Racing
Silverbulitt@msn.com
Our websit www.PXRacing.com is coming soon!!
We carry Contour/Cougar parts for the 2.5 Duratech and 2.0 Zetec
