Posts: 59 |
Weapon-R is debating the production of a new dyno tuned aluminum intake manifold for the Cougar/Contique. This new manifold will be a combo of Upper AND Lower in one!
Early estimates are looking to see a 20hp gain when using intake/exhaust/intercrew ecu.
ALL feelings, suggestions, ideas are welcome.
ALSO, if this were to be produced, how much would you be willing to pay.
Leo from Weapon-R will be here to answer your questions.
Administrator
Administrator
Posts: 5,037 |
Will this be a bent tubular aluminum intake? If so, I would consult the master for the design. (Terry)
Posts: 351 |
For 20hp, I would pay $500 + shipping. Would it include new injectors? If 24 lbs injectors, I would go $600.
98 Contour LX V6 Mtx
Posts: 1,444 |
I think we need to see some kinda prototype plus a dyno. If you get all that I think you'll get a bigger response.
Posts: 4,042 |
Originally posted by IndyTour: For 20hp, I would pay $500 + shipping. Would it include new injectors? If 24 lbs injectors, I would go $600. Ditto. 20hp gain over SVT or reg. Duratec manifolds? If it's 20hp over reg. Duratec, no thanks. John
Posts: 7,329 |
20HP over what I have right now and you we are talking...
$500 sounds steep. For a little over half that I could EH mine again. IIRC Leo is running 330+ crank (N/A) with a slightly enlarged DH SVT upper manifold. So the stock manifold can make power.
Posts: 2,708 |
Would it be able to handle positive intake pressures beyond 7psi? -Mark
You can do something for Love... You can do something for Money... But there is nothing quite so satisfying as doing something out of Spite. GTExtreme1@aol.com
Posts: 2,066 |
Originally posted by DemonSVT: 20HP over what I have right now and you we are talking...
$500 sounds steep. For a little over half that I could EH mine again. IIRC Leo is running 330+ crank (N/A) with a slightly enlarged DH SVT upper manifold. So the stock manifold can make power. Is this all he has done?
Posts: 47 |
"This new manifold will be a combo of Upper AND Lower in one!"
Does that mean Bye-Bye Secondaries?? or would the IMRCBox/Cable be incorporated into the new Intake manifold?
98 Contour SE Sport ATX lightly modded... =0) 14.1 @ 98MPH 1/4 mile!!! New Version 3.0 inside =0)
Posts: 5,805 |
So the injectors move/relocated and a new fuel rail........????
