Before reading this, please be advised WeaponR is looking for a CEG member to swing by their San Francisco location to see if the contour hood affects this box at all.
Weapon*R's new Cold Air boxes are made of 6061 Aluminum, Lazer Cut and precision folded for a clean and true fit. The Weapon*R Cold Air Box is the answer to enthusiasts which want the cold air performance, but are weary of the dangers which come with conventional cold air kits.This kit utilizes Technology seen in many forms of racing.
Keeping the filter in a safe area and Isolating the filter from Horsepower robbing heat.
Intake System NOT INCLUDED.
May Be purchased Separately or with Intake System.
Photo:
http://www.weapon-r.com/images/box.jpg Built For The Dragon Intake
Our Never ending pursuit of perfection has led us to create The Dragon Filter. The design concept of the dragon filter was to refine the V2. Our research and development team, aimed towards designing a filter that dramatically increased airflow and velocity of the intake charge.
With use of our Patent Pending design of the Air Turbulance Defuser, performance is Virtually Unparalleled with the use of the Internal Twin
Velocity Stack, Ram Air attachment capability and louvered external Air Guide Cage. We now feature a Three piece design. It was specifically designed for the ease of cleaning and filter element replacement.
Add On Ram Air Kit
The Dragon Filter Ram Air Kit is an addition to the performance section of the 2002 line-up. The Ram Air Kit comes with an adapter for the top of the filter, a flexable hose and a universal fit ram air snorkel. Performance Gains will be noted immediately. Ram Air has been an age-old horsepower producing factor. Why? Because it has been tried and true. The kits are available in the same colors as the Dragon filters for easy
color coordination
Colors are: Red, Blue, Yellow or Chrome
For those of you with the KKM or Injen. This box is capable with your intake but you will have to drill a hole in the box for the IAT sensor.
Order Today:
http://www.customcougars.com/performance/weaponrstages.htm Thanks and expect more products from Cougar Parts Online in the coming month.
