Page 2 of 2 1 2
#1491037 01/30/06 12:22 AM
The dyno isnt really neccessary when it comes to tuning a car. Its the software thats really important (i.e. SCT). If you dont have tuning software then a dyno is useless.
#1491038 01/30/06 04:42 AM
So they couldn't hook up their laptop to my car and adjust the a/f ratio things of that sort?Or do i have to buy a programmer.How is the sct quality/function wise?
99 SVT/silver frost....with "some" mods SVT FLYWHEEL 4 SALE!!! PM me
#1491039 01/30/06 02:26 PM
Y
Y
This thread is going to get WAY out of hand with questions like this, Brandon. It's clear that you know little to nothing about tuning, so I would do some serious reading on the subject, and then come back for questions. This isn't meant to be a joke either.
Mark
#1491040 01/30/06 05:58 PM
alright then
#1491041 02/04/06 04:57 AM
For an ideal tune, it should be done on a Dyno, the best choice being a Mustang Dyno since it simulates actual driving conditions. It takes into consideration the vehicles weight, and loads the drum according to that weight. That coupled with SCT's X Calibrator 2 will give you the ultimate tune. Once tuned, the X Cal 2(handheld) now gives you the ability to manipulate the tune by +/- 2%. It also has Datalogging capabilities. On the Dyno you can also look at AFR, EGT's etc (if Supercharged you can look at boost pressure, inlet temperatures etc). With other software (sneecer) you can look at MAF voltage, injector duty cycles, injector pulse width, commanded advance and a lot more.
Most mail order tunes are based on information provided by the end user, and are 95% on then "rich" side when it comes to fuel, so optimum performance is never gained.
Hope that helps a bit,
Ron
Page 2 of 2 1 2
Moderated by  mbb41_dup1
