Page 1 of 3 1 2 3
#1490056 01/27/06 03:15 AM
I searched and found no mention of them (Didn't check the archives though). The information I have shows completely different cam timing than the SVT cams and according to my simulations, they seem to work alot better with our 3.0L than the SVT.
Are they actually different? Any part numbers? Sourcing/pricing?
Driving the Caliber Side project: The LT-5 Fiero is being born..
#1490057 01/27/06 03:23 AM
never heard about this...could be...
#1490058 01/27/06 03:55 AM
Yes, they are different. Part numbers all start with 2S7E and they can be identified by their purple color codes versus the old SVT's yellow. I doubt that they are available to dealers in the U.S. I wonder if they are even released for service to dealers in Europe.
#1490059 01/27/06 05:10 AM
They are slightly different. IIRC the SVT exhaust cams were a little more radical than the ST220 exhaust cams, but vice versa for the the intake cams... or was it the other way around.....
Matt 2002 Subaru Impreza WRX (WRB Stage 4+) Old Rides: 1999 Sil-Fro SVT Contour 3.0L with goodies (Totalled 6/21/06) 1988 Bronco II (Sold) You know you launch hard when you beat oncoming traffic through their own crosswalk lines.
#1490060 01/27/06 04:46 PM
Well we can get the ST220 springs (Which oddly list under several of the newer Ford/Mercury/Mazda 3.0s when I search by part number of FPO or Y2KFord), I tried plugging in the 2S7E with the rest of the SVT and non-SVT cam part numbers and nothing came up on Y2KFord.
#1490061 01/28/06 01:24 AM
That's because they are not specifically used for the ST220. It's a common, shared spring between all 2.5/3.0L Duratec. But it's genesis was for increased durability on the ST220 application.
#1490062 01/28/06 02:51 PM
W
W
I don't have the specs for the ST220 cams.
Do you have them to post?
#1490063 01/29/06 06:34 PM
From Cat Cam's website on "OEM" ST220 cams:
Duration (0.1mm + cl): 258/264
Duration (1.0mm + cl): 212/214
Maximum lift: 9.75mm / 9.70mm
Timing (1.0mm + cl): in 0/32 ex 37/-3
#1490064 01/29/06 09:45 PM
W
W
Thanks.
#1490065 01/30/06 03:24 AM
9
Those specs seem to be the OEM specs for the 2.5 duratec listed on catcams website...
I also didn't see any info on st220 cams on their site
3.0 14.392@97.237 2.302 60ft OEM 4-bolt LCA's $105 each Watch me go
Page 1 of 3 1 2 3
