Posts: 1,841 |
Where should I buy one from... I want it relatively quick and relatively cheap. I've seen it for $369 plus shipping... Is there anywhere that I can get it lower?!
"I sense much beer in you.... Beer leads to intoxication, intoxication leads to hang over, hang over leads to suffering....., suffering leads to the dark side." -Chineseman 3:16
Steve Chang 99 Silver SVT #196 "ExtrudeHone" Sponsored by Street-Concepts 174.2 fwhp @ 150.7 ft/lbs (218 hp @ crank) - Pre-Headers SVT/SHO Society Vice President XChang Designs
Posts: 5,805 |
Thought you were sticking with steel???????
Posts: 1,447 |
When/if you find it cheaper, let me know. I need a new flywheel and clutch
Posts: 583 |
Originally posted by Terry Haines: Thought you were sticking with steel??????? Terry is Aluminum ok? or is steel better? Eric
First I would like to congratulate my 2002 "The Perfect Storm" undefeated National Champions MIAMI HURRICANES*1999 Ford Contour SVT #206 00 SVT motor with Return fuel*Black-Tan*Cold Air Intake with 6" S&B Funnel Ram*Sho-shop off road y*Brullen Cat-Back 3.5" slant tips no res*Unorthodox racing crank pulley*Lotec Guage pod with Air/Fuel, Oil Pressure and Voltage*17" Image Tuners*215/40 Falken Ziex's* B/M Short Shifter*Nokya 9006/9005 80w/100w Xenon's*JSP wing*BNM White Faced HVAC*Custom svt emblemed rear*Bosch +4's*H/R springs*Euro Sidemarkers. Eric@ritterpenusa.com Centerforce Dual Friction Clutch and Fidanza Flywheel.
Posts: 333 |
aghhhhh you *******!! Well I will still kick you a$$!!
Silver 99 SVT It's Stock. Would I LIE?
My cars the Silver one
Posts: 1,841 |
What!? Since you are going to Mod your, I can't mod mine to beat you?! I sense a little worriness in your voice Dave. Terry, I was going to go with steel, but the price difference between the two is realtively small, so I'm going with the Fidanza... Since it'll gimme 200 hp more...
Posts: 5,805 |
Your the customer,I'll fit whatever you want....
Posts: 2,794 |
I would take that as a small warning.....
Just call me Judge. People suck. Life begins at 170mph...until that point it is just boring.....
Posts: 1,036 |
Im curious... what is the difference in using an aluminum one vs. a steel one? I am scheduled to have a Fidanza installed by Terry and would like to know any hazards involved with aluminum!
98 E0 Silver SVT KKM - Bassani - MSDS - BAT - ES - Unorthodox - HID - Dyna-batt - Koni - Ground Control - 17" MAS Italy Rodger - Quaife - Fidanza
"Every easy girl I have been with has been either a hosebeast or a headcase" - Pete D
Posts: 1,841 |
Really no hazard, just that you don't want Aluminum to be touching the Clutch, since it'll chew it up, but the Fidanaza has a steel insert that touches the clutch so it won't hurt the flywheel. The aluminum part is there for weight reduction, nothing more, nothing less. That is how I interpreted me and Terry's chat.
