First off, I did search and didnt find anything to relevant. Second, tha car is a 1998 CSVT, 2.5L Duratech, 5 speed, all stock with 788k miles. The car has had the UIM/LIM and IAC cleaned, new water pump, new plugs and I think new PCV and fuel filter about 8-10k miles ago.
The problem: The car normally idles about 1k RPm on the factory tach. When cold out and car has been sitting it idles real rough for about the first minute and surges/stumbles. After that point it idles and drives fine. It also has what feels to be a miss (like a bucking sort of) at low RPM (under 2000) under high load. RPMs never jump, so I dont think it s the clutch going out. Car has a CEL. Ideas?
Also, is there a way to pull codes without having the car scanned?
