Yes I searched and read the FAQ and it says the manual requires 5.8qts, but in the walk through it says 6.5qts to fix the oil starvation problem. My question is...should I put 5.8 or 6.5? Do a lot of people use 6.5qts to fix this supposed problem or is this just one guys opinion? I would like a few peoples view on how much oil they put in instead of just one. Thanks.
Absolutely run 6.5 qts. If you get it too full you end up bathing the rank and losing power/foaming the oil, but that happens somewhere north of 7.0 qts. 6.5 is good for the street, when racing I run 7qts, without problems.
