well some of you may know my diferential let loose over thanksgiving. i had a spec stage 1 and a torsen installed. well they said the old synchros looked good and they were to be reinstalled, flashback to today, i now have grinding in all forward gears, not always but still grinding. so this sunday my car is goin back to Michigan to be reserviced. i need to know the part numbers for the 1-2, 3-4, 5-R synchros. any other suggestions on things to replace? thank you, i have to get back to class because my house doesnt have internet yet.
2002 Cougar 2.5 duratec/ mtx-75 85,0000 Mondeo ST-200 wheels/BFG KDW NT black/black Spec Stage 1 Torsen T-2 Trubendz 2.5 flowmaster dual exaust apexi s-afc II K&N FIPK
Point 1) Crunching in all gears is usually a clutch
bleed issue...and/or wrong(short!) Zetec slave fitted
to a V6 trans!.Point
2)Late MTX's will have the single 3rd blocker...yes we can revert to the better twin set up as we have blockers,cones AND the gear that has to be changed!!
Point 3) What sort of 'trans shop' doesn't know the correct part ###'s!!!....I'd run!!!!!!!!!!!
i dont need parts number, i wanted the part numbers for the better fitted synchros, but im now in contact with TH, so hes helping me out, it is not a clutch issue. unfortunately. thank you.
Thank Terry I just copied his email.
