Posts: 4,270 |
I have a Dell Latitude and all of a sudden my touch-pad mouse seems to be acting quite awkwardly, if i try to move the cursor after i let off the pad it seems to quickly "pull" itself back to a different position, anyone with an idea as to why it is doing this and how to fix it?
~Alex
Ex- SVT Driver627
MUST SELL!!!LOCAL:
Pre-98 MOLDED trunk
Polk db speakers
Corolla parts
LED Underbody Kit
PM
2000 Green CSVT gone on 2/17/06
2001 Toyota Corolla (SHE RUNS!!!)
1989 Mustang LX 5.0
Posts: 2,978 |
Obvious question:
Is the touchpad clean? Have you made sure that nothing is on it? If there is dirt or something on it it could see that as your finger and when you move it pulls it back... just a thought.
Posts: 4,270 |
Just cleaned it and it still did it, but suddenly a few minutes later it's working again.
~Alex
Ex- SVT Driver627
MUST SELL!!!LOCAL:
Pre-98 MOLDED trunk
Polk db speakers
Corolla parts
LED Underbody Kit
PM
1989 Mustang LX 5.0
Posts: 3,738 |
have you recently given it a static shock? i onced had a touchpad die on me from walking across carpet and when i touched it POW! it was dead.
~Andrew
2001 VW Jetta Wolfsburg Edition
20 valves of fury
Posts: 7,431 |
Originally posted by Lebowski316: have you recently given it a static shock? i onced had a touchpad die on me from walking across carpet and when i touched it POW! it was dead.
~Andrew
Sounds pretty likely ... the symptoms described sound just like if you were holding two fingers on your trackpad and trying to use it that way (the cursor compromises by going in the middle, then 'pulls back' toward the other finger when you let go of one). There may be something encouraging the cursor to believe that there is contact somewhere on the trackpad.
Posts: 777 |
I have noticed improvments by updating the touchpad software. Go to Dell and check it out
Posts: 299 |
This may be a little late, but here
98' Black SVT
Build #1915 of 6535
