warmonger and giddyup306 do you guys know what your main journal to bearing clearance specs were. im at the top of specs on three journals and .001 out on the fourth. is this of great concern in the 3L? i have clevitte 77 std bearings. crank is within specs.
also what were your piston ring end gap specs i am sitting a little out of spec on those as well...to much gap...
anything will help
