Hello again,
First off, thank you to everyone that contributed to my previous post. Ok, ran test and it pulled up a 225 which is a knock sensor fault? Would this explain the erratic rpm fluctuation when in park or in drive. You can hold the rpm around 2K and it will significantly fluctuate. You can also here it miss at the exhaust. Where exactly is the knock sensor on a 95 Contour 2.0L?
I have changed plugs, wires, MAF (it came up faulty the first time), fuel system cleaned, fuel filter, etc.. and it still runs like poo.
Oh and there also seems to be abnormal amount of moisture coming from the exhaust.
Thanks in advance for all of your suggestions.
