Posts: 11 |
I was wondering if anyone knew whether the 65mm TB would be a direct bolt on for a 98 SVT? Any help or info would be great. Jami
98 SVT B&M Short Throw Shifter KKM Intake 9mm FMS Plug Wires Bosh Platinum +4 Plugs
Posts: 4,528 |
Yes but the dyno is not good. Stock flows plenty from what I know.
Posts: 3,419 |
Unless you have some sort of A/F adjuster, you'll probably lose a few hp doing that. With the ability to adjust A/F, you are golden and it is a great mod.
Posts: 7,329 |
It's also not a "direct" bolt-on. It will require are few modifications to work properly.
Posts: 539 |
where do i get my hands on one
jiako|98 svt silver|kkm true rev|18" Enkie RS5 wrapped w/falken GRB FK451 215/40|Mesh grill| Sony headunit|Boston Acoutics (4)5X7|Memphis 1100 amp|(2) JL 12W3|KVR X drilled rotors|35% tint|2.25" True Duals w/ Magnaflows| kkm pedals|LSD|Fidnaza Flywheel|Centerforce Dual Friction Clutch|FMS wires|Konis/Eibach|ESP bushings and Mounts|75MM PRO FLOW|DMD|Aluminum shifter & E-brake handle|SAFC|HID's and a few more cc's 196.1 and 183.4
Posts: 3,419 |
There is always ebay. Or (I can't believe I'm doing this) SHO Shop sells a 63mm TB which is a bored out SVT TB. Direct bolt on. Summit has some 65mm and 70mm TB's in the Mustang section of the catalogue.
Posts: 7,329 |
Originally posted by PA 3L SVT: Summit has some 65mm and 70mm TB's in the Mustang section of the catalogue. It's the TB off a 4.6L SOHC Mustang (some crown vics) Not the 5.0
Posts: 3,419 |
Summit has some for 4.6's too. BBK-1700 (70mm), -1701 (75mm). Cheaper than SHO no less.
Posts: 414 |
Don't forget, just switching the MAF does not mean gains. The maf needs to be calibrated for conical air filter. Can someone explain this a little better of direct to the old post on this topic.
98 EO #587 Currently Dirt Jumping
