Ok, I have searched far and wide to avail. Well, I have a 96 Mystique instrument cluster (electronic) I have seen several posts about this swap to a 95 contour but mys question is what do I have to do change over the cable driven instrument cluster to the electronic? By the way, I have swapped the engine out of the 96 to the 95 tour. Had to swap out the engine harness from the old to the new. I have the electronic speedo pick up from the new trans. My thoughts are that I should be able to pull the cable out and press on. Am I wrong???
Thanks
Greg
