#1481901 01/15/06 11:03 PM
Seems like my fuel pump is on its way out. Engine dies out and it's a lot worse if the tank is low. What is a good replacement? Read through this forum and have seen posts about the fuel pickup screen. They way it acts I don't think that's the problem. It sort of shuts down and then comes back??
Also, what should I expect to pay for a new blower resistor?
Al 2000 SE Sport. 55K miles.
Originally posted by Big Al:
...Also, what should I expect to pay for a new blower resistor?
$15 to $20 for the part. Labor is probably one to two hours. Do it yourself for free.
Edit.
Check out this thread for the part numbers.
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=trouble&Number=1089739&page=&view=&sb=5&o=&fpart=1&vc=1
and this for info on how to change it.
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=trouble&Number=1041830&Forum=All_Forums&Words=23307&Match=Username&Searchpage=0&Limit=25&Old=allposts&Main=1041830&Search=true#Post1041830
i was having a problem with my fuel pump so to took the screen off and now it works fine.
if you havent changed your fuel filter do that
and fixing your pump is easy and its worth a try.
2000 contour V6 ATX BAT suspension kit, k&n filter, SVT TB, SVT UIM, SVT LIM, MSDS headers, MSDS Y-pipe, SVT dual exhaust, Custum burned ADC chip, 7000k HID's, 200 amp HO alt, custom gauges, and 17" rims
Buy The FSVT Smartpump man... If You're Going To Remove Everything To Get The Pump Out And Remove The Screen...You Might As Well Put A New Pump In It. The Returnless Style Pumps Seem To Clog A Lot And Fail Prematurely Just Due To The Design Of The Returnless System. The Pump Itself Is Only Around 110$ And Is Plug And Play. ICEFURY And I Just Installed One This Weekend. We Pulled The Entire Tank Which You Dont HAVE To do, But I Recommend It So You Can Clean Out The Crud Trapped In The Tank. Definitely Do This Mod If You're Going In There Anyway. If You Need Any Pointers Pm Me Or ICEFURY.
CSVT E0 3L 14.5 @ 94mph, Stock Intake, Stock Exhaust minus Resonator, CEL, And Broken Pass. Side CV...Untuned.
Edit.
Pulled the blower resistor about a month ago. Scraped the coating off and repaired it. So far it holding but I'm afraid to use the second highest speed. That was the part of the element that burnt open. I'll pick one up and replace it.
Al
It's getting worse:) This morning it was hard to start. After cranking a while it fired up. Backed up, started to go forward and it quit. After a while I was able to find the Schrader valve and tested for fuel. None. So I added two gallons of gas and cycled the fuel pump a few times. Fired right up, ran rough a few seconds and is now quasi normal. It won't be long now:)
Al
