#1481654 01/15/06 07:26 AM
Does anyone else have a stutter or hiccup when you hit the gas anywhere between 1K and 3900 RPM? It just seems like the engine is skipping..just replaced the plugs and wires have less than 15000. I thought this was normal...but maybe not? Help!
#1481655 01/15/06 07:43 AM
Most likely a fuel problem. Do the maintenance first. Clean the throttle body and add a can of high quality injector cleaner to the tank (I like RedLine or Techron).
#1481656 01/16/06 01:09 AM
Originally posted by gonzo1615:
...just replaced the plugs ..
Make sure the gap is 0.054 and the spark plug wires are routed correctly (especially the 4-6-5 at the coil).
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=trouble&Number=956805&fpart=1&PHPSESSID=
