Posts: 139 |
howdy, I finally got rid of my bank too lean code.. I changed the MAF and poof. now I have a EGR Flow Insufficient, I believe that's a P0401. so I did a search on how to clean this stuff and there are no pictures that I see.. so uh here are mine.. maybe someone could point me in the right direction as to what to clean?? I know, it's quite dirty.... there was a gutted cat on the car for a while, now that everything is replaced it would see like that is taking it's toll. here are the pics Pictures
-Mike
96GL
2.0 Zetec
CTA Intake
SVT Exhaust
Posts: 5,345 |
1996 V6 ATX 96K miles
Posts: 139 |
um, err.. I cleaned the TB, but how exactly do I clean the rest of it.. that chamber looks pretty deep?? if I drop something in there, I doubt it's comming back out?? I'm sorry - block head here... maybe some arrows would help? lol
-Mike
96GL
2.0 Zetec
CTA Intake
SVT Exhaust
Posts: 5,345 |
Originally posted by sir_break_a_lot: ..... that chamber looks pretty deep?? if I drop something in there, I doubt it's comming back out?? ..
Ah..., see the white paper towel or cloth? Helps prevent things from falling in.
Posts: 139 |
cute lol, no but I mean, what am I looking for, I just bought a new flow sensor thinggy... I forget the acronym.. um I changed that and now im gonna clean the TB with the spray from ford.. anything else I should be concerned with? I mean basically wha tI'm saying is.. that thing on the intake monifold w/O the TB present.. I have to clean the whole inside of that with like oh I dunno a sock or something?
-Mike
96GL
2.0 Zetec
CTA Intake
SVT Exhaust
Posts: 139 |
well I think I found what the problem was after I went out and bought a 100 $ part.. DAMNIT!  I had needed custom work on the exhaust and they CUT the EGR metal pipe and linked it to the cat with a "high temp" rubber hose... the first hose melted, this one melted... I am annoyed. someone please verify for me that the EGR tube is metal for a reason. is if possible to use rubber/ he's telling me the engine is running hot. over 15K in this car I HIGHLY doubt the temp is a problem(abnormal) I think if I had a metal to begin with I want a metal or better this time. you know? I feel like pulling the guy aside and saying "if you were going in for a heart transplant, would you want an equal human heart, or a subversive chicken or lamb heart?" I mean, what gives! if I didn't love this car so much... phew.... *vent off. but seriously.. anybody know if the EGR SHOULD be metal? and maybe if every EGR on the planet is metal?? I don't like being told it's my fault when I pay to have a job done and get the "rubber" shaft... you know what I'm saying?
-Mike
96GL
2.0 Zetec
CTA Intake
SVT Exhaust
Posts: 5,345 |
Yes, the EGR tube is supposed to be metal and it gets hot and that is why there is a "heat shield" over it.
Check out Chongo's picture with the EGR tube and the "heat shield".
Posts: 82 |
In the pic Tony posted the EGR is at 1 o'clock, I'm guessing you know that.
On my 2.0L the EGR also has a 90�º bend. Crud builds up in that bend and probably needs to be picked/ scraped out. Gently. You don't wanna damage the thing.
Oh, your last post!
You could problably get away with soft copper, it's bendable enough to route it. Otherwise, fix it with a boneyard part, or new. Then sue the goofball in small claims. You'll win.
Then you'll have to file another case to collect unless he's a shadetree guy and takes off.
95 Contour, 2.0L, stick, 178K mi.
