Assuming this is the Fuse F-37? Do you have a Ford Cd manual, it would be a BIG help, the AC clutch/solenoid, several relays in the BJB fuse box, several swithces (AC compressor cycling, and the dual pressure on the evaporator cans under the battery and a diode on the left side of the passenger side cooling fan are also on that fuse.
It looks like the make contact on the heater blow relay k-14 feeds all this and the heater blower motor.
Unplug the AC compressor clutch (actually pulling relay K-107 in the BJB box - Ac clutch relay would isolate the diode and the clutch solenoid) and the heater blower (connector that plugs into the side of the motor).
I'm looking the wiring diagrams and the associated pictures in the Ford CD manual. The pictures assume you're familiar with the whole car.
This CD manual is mandatory before the guessing begins!!!
Ah I mean troubleshooting!
Good Luck
Paul
