I was wondering what is the "normal" temperature supposed to be. Assuming sensor and display are calibrated, is the normal setting in the contour dashboard supposed to be such that the gage points to straight up? THere is no actual degree reading in the display of my 1996 Ford Contour GL 4 cylynders, manual (75000 miles).
That is what I thought was for 9 years, but I have noticed that it has been half way between up and the red zone.
The reason I am worried, is that I have just done the troubleshooting of the P0171 code, changed oxigen sensors, and what finally removed the error (at least for now) is the cleaning of the MAF sensor that was suggested by some members here.
What would be other reasons for slight average overheating (other than the cooling system)? Can a vacuum leak still be lingering?
I rewrite that the "check engine" light appeared interestingly enough *4* times on the same driving place and situation: as I was accelerating in 2nd gear going uphill 10% steep road at 5200 elevation (after a 3 mile freeway). I could not reproduce the alert to trigger when going on similar uphill/gear *not* after freeway driving ...
Hope all this can spark ideas to put together a theory that matches all these signs.
thank you very much! stefano
