Hello.
Using Ray's handy alternator swap how-to
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=v6maint&Number=838883&page=&view=&sb=5&o=&fpart=1&vc=1And I've got the alternator removed.
Working on a 98 SE V6 ATX
A view deviances which may be model year or the fact that I have an ATX aside, a very well written piece, thank you. When Ray says "use 8" extension" he means it!
On to my question. I can't put my hand on either of the bottom two bolts, I removed them entirely by the 'back out until they fall to the ground' method.
I am concerned that I won't be able to start them again, since I can't get a hand on them and both came off with the flex in the chain of extensions.
Does anyone have any advice for me? I know to use a scrap of papertowel to temprarily hold the bolt into the socket, and I saw to align the Alt using a bolt backwards, but, I'm very nervous about getting those bolts started.
Largest problem is there are two power steering lines directly below the back of the Alt, so I can't stick my hand up there, even to steady the socket end. Maybe I can rig up a stick or something to try and hold it in line. Now that the Alt is out, I might look to move the PS lines, but thats been my only thought so far.
Removal took me about 5 hours. It was just hard to get to the bolts with my extensions cause I couldn't duplicate exactly the lenghts Ray did, but I needed to. 6"+3" isn't 8" no matter how hard you wish it to be
![](/ubbthreads/images/graemlins/frown.gif)
You fellows who are doing this in an hour or even 3, my hats off to you. I did also look into Todras method through the driver side wheel well, but there was no going there, I couldn't even see across the car.
Thanks again Ray for the write up.
Scott
