All done, took me 4 hours. Only hassle was the fuel rail and the injector harness, just not enough room to work in there!!!
Thanks to a CEG'er who sent me the special tools for disconnecting the fuel pipes (not available in the UK) otherwise I would still be there!
One thing I did do was mask off the open holes of the intake, oh too easy to drop something down in there!
Been for a spin, seems a lot smoother, pulls more before the secondaries open up. For those interested in the size differences between the std Duratec lower manifold and the ST200 one, std to ST200 bore sizes are as follows:-
Primary bore 30.8 / 33.0mm
Secondary bore 32.0 / 34.7mm
I took a few pics during the install:-
And finally the two lowers side by side
Anyone want a set of brand new SVT green injectors???
5 Dr, 2.5 V6 Ghia X, 1999
Modifications:-
Inventor of the inductive Secondary monitor
Chrome grill
JR cone air filter
Black Diamond cross-drilled & grooved discs with Predator pads,
ST200 throttle body, upper and lower extrude-honed intake manifolds
Scorpion s/steel exhaust
Current Project.. Building a ST200 powered MKI
paullorman@btopenworld.com
Paul, please don't tell me those are the manifolds you picked up while here!! You are just now getting around to installing them????????????????
1991 GVR4
Lots of mods done.
Nope, the upper I put on the day after I got home. Just bought the lower from BAT, now I have a matching set!!
Modifications:-
Chrome grill
JR cone air filter
W
W
Whats the flow rate on the green injectors?
My '99 SVT has orange injectors, and the 3.0 that I bought had Blue injectors. Anyone know the color rating system? PM me.
warmonger
You can call me anything you like as long as it's nice.(all lies accepted)
99 Silver Frost SVT. #226 of 2760
Engine: 3.0 power!
Unique Stuff: Sunroof control module (#1 of 9)
Car Audio: Loaded and loud!
Check them out at
http://home.earthlink.net/~twilson1726
I
I
I want them, if they fit, how much? My a/f ratio is a very low 14 instead of like 12.5 since I opened up the exhausts. I think the larger injectors will provide the fuel I need. Let me know.
98 Contour LX V6 Mtx
Green injectors are 19lbs
And are for the returnless fuel rail...
2000 SVT #674 - Check it out!
I
I
I am out then. I am return.
I'm interested in the injectors e-mail me a
price:
jskinger28@hotmail.com
Thanks!
2000 Roush Cougar MTX
MSDS Headers, Rear disc conversion, SVT TB and IM, Custom 2.5" exhaust, Weapon R Dragon w/kkm MAF adaptor, B&M, NR wht gauges
W
W
So what rating are the light blue injectors that came with my 3.0 taurus motor?
What duty cycle is the rating at?
I would assume that 19 lb/hr would be with no higher than 80% duty cycle.
warmonger
Engine: 3.0 power!
Check them out at
