Posts: 214 |
Winter storm warning for me here in Hartland, 5-8 inches by tomorrow afternoon. I thought about rolling that way with another SHO owner tomorrow but not sure now.
If the weather is really bad for everyone there is a tri-state sho/svt meet next weekend in Frankenmuth. Not trying to steal the thunder, just an fyi in case we get hammered with snow.
Posts: 6,791 |
C-Maro is coming fO shO
Back In Black
Back In Black
Posts: 3,119 |
I'm still planning on being there, however, my car is broken so I'm going to have to bum a ride to get there.
Posts: 5,143 |
So about the weather... if the roads are that crappy... Im not going... I put my other rims back on... There is no way I am going to attempt a 2 hour drive in that kind of weather with Comp T/A tires.
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 7,392 |
Originally posted by AliasJerk: So about the weather... if the roads are that crappy... Im not going... I put my other rims back on... There is no way I am going to attempt a 2 hour drive in that kind of weather with Comp T/A tires.
you do realize winter didn't end early, right?
.....______
___|______\_____
|/-\_________/-\_|
.\_/...............\_/
Posts: 5,143 |
Originally posted by MxRacer: Originally posted by AliasJerk: So about the weather... if the roads are that crappy... Im not going... I put my other rims back on... There is no way I am going to attempt a 2 hour drive in that kind of weather with Comp T/A tires.
De De dee. I plan to get new tires soon, and sell the steel rims and tires.
TEIN H.Tech Springs
Posts: 2,728 |
I still plan to at least swing by around noon. Depending on weather we'll see how long I stay.
'03 SRT-4
50 trim turbo + support
Posts: 5,143 |
Originally posted by AliasJerk: Originally posted by MxRacer: Originally posted by AliasJerk: So about the weather... if the roads are that crappy... Im not going... I put my other rims back on... There is no way I am going to attempt a 2 hour drive in that kind of weather with Comp T/A tires.
Steelies are back on... Somehow my SVT rims went super out of balance... I found this out when I went 55 and my entire car started shaking Oh well, ill have to get them balanced anyway when I get the new tires.
TEIN H.Tech Springs
Posts: 2,728 |
FYI, tires don't just go "super out of balance". You either mounted them on wrong or the weights possibly got moved and/or knocked around. Most wheels don't require enough weight to cause a huge problem, espcially at 55mph, even when the weight is moved to the wrong place. If your wheels have less than 1.50oz then you have other problems. Get your tires checked out or see if you didn't mount them on wrong somehow.
And on second thought I might try and come earlier around 11:30 and stay for a bit and come back home to get my stuff before I head to Port Huron.
'03 SRT-4
Posts: 7,392 |
i should be there noon-ish. anyone else punking out because of a little snow?
.....______
___|______\_____
|/-\_________/-\_|
