Posts: 1,785 |
Can any of you tell me what KR means? Post I was thinking Knock Retard (Timing). Trying to learn about these cars. I may pick one up in the next few months. Hoping for an all black Buick Regal GS
Just a Plain SE.
AKA Big Country
I maybe path914's B**** now, but wait until he needs his clutch done. We will see WHO is WHO's B**** then!
Posts: 5,854 |
yeah i was looking into pulleys/exhaust/chip/etc. for my cousin's new GTP. I don't know wtf KR means either...I even searched the site/faqs for a definition of the term but didn't come up with anything. I didn't feel like registering for the site.
1999 Silver Frost SVT
#609 of 2760
Posts: 3,496 |
If your going Regal GS, try and find one with an Abboud package. It spices up the interior a bit as it's horridly boring inside.
Posts: 766 |
Apperently in '01 or '02, they had a GSE package. Which I think had suspension and audio upgrades. I looked at getting one too. I'm going to buy my landlord's 1993 Lesabre for $1500. It's got 103k on the clock and in great shape. Only 170hp, but 220ft-lbs. I know it's a grandma car, but the contour needs some work and I'm not putting money into that thing. Plus, my back is getting worse in my old age. Supposed to be a bulletproof motor.
Ken
PackRat is my hero!
Posts: 1,939 |
Picking up a 2000 GTP on Monday! Can't wait! Heard nothing but good things about the 3800
2000 Silver Frost SVT
# 1637/2150
D.O.B. 01/14/2000
Posts: 2,469 |
Originally posted by myfastse: Can any of you tell me what KR means?
Post
you and the misses replacing the civic after you move?
Posts: 191 |
KR does infact mean knock retard. When the knock sensor tells the PCM it hears knock, the computer will pull timing from the ignition. GM 3800 S/C motors fight a lot with knock. Increasing the boost will cause more knock because the incoming air is hotter, and under higher PSI. Tuning is critical on these motors, they typically need reduced timing and lots of fueling to fight off the KR and harmful detonation. KR is so bad because it really hurts performance. Every degree of ignition advance is worth between 1 and 3hp. So, if the computer pulls 10* of timing, there goes 20-30hp. And the recovery from KR is slow, so it doesn't add the timing back in very fast. They usually hit KR right after a shift and then the second gear sucks because its slowly restoring the timing. And if you're seeing KR, you're very close to, if not detonating, which is very harmful. Hope that helps. I know the GM stuff a lot better than the Ford, I learned a lot about the PCM systems when I did all the work on the Grand Am.
Current Ride: 1998 Contour SVT - T-Red, Res. Delete, K&N under the hood, broken side skirt at passenger rear jackpoint.
Its FOR SALE, see the classifieds.
Posts: 9,065 |
Originally posted by klavender: Apperently in '01 or '02, they had a GSE package. Which I think had suspension and audio upgrades. I looked at getting one too. I'm going to buy my landlord's 1993 Lesabre for $1500. It's got 103k on the clock and in great shape. Only 170hp, but 220ft-lbs. I know it's a grandma car, but the contour needs some work and I'm not putting money into that thing. Plus, my back is getting worse in my old age. Supposed to be a bulletproof motor.
I love mine...runs great
Posts: 147 |
http://www.3800pro.com/forum/Under "Newbie Zone" they have a list of most of the acronyms. The guys on this site are extremely knowledgeable about upgrades and modifications to these engines.
2005 S/C Monte Carlo SS
1995 Contour SE
Posts: 2,116 |
another decent site is www.regalgs.org. The GSX regals are niiiiiice. Wish I got me one of them. Oh well.
95 SE MTX
svt exhaust
intake
deer killer
