my 98 se is rubbing when ihit dips all my tires rub the fender. i did replace the front 2 shocks but not any springs. can any1 tell me the problem and how much it will 2 fix
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
ok but i have stock rims and tires. i had 18s but switched back 2
factory tires and rims and they are rubbing do i need new springs if so how much will it be
Where is it rubbing? Are you sure it's rubbing and not something else?
AUSSIE ENDLINKS $70
Originally posted by Porgieanne316: my 98 se is rubbing when ihit dips all my tires rub the fender.
1. All 4 tires are rubbing? How do you know? 2. Where is the rub on each tire? 3. How many miles on your car/suspension? 4. How fast are you taking these dips?
Are you sure you're not taking these dips too fast and the car is bottoming out?
I can hear all the tires rubbing on the tire and i can see the marks on the tires where the fender is rubbing on it.i am not sur what bottoming out is but this did not happen before i put my 18's on and otok them off does ANYONE KNOW how i can get my car to stop rubbing on th fender when it hits a dip'/
sounds like some good ol fender rolling to solve the problem . do it at home your self with a heat gun and baseball bat
wedge the bat between your tire and fender push down on the handel and roll it along , to push the lip up . and in the mean time have some one useing the heat gun on the paint so it dont crack .
Originally posted by turbotrix: sounds like some good ol fender rolling to solve the problem . do it at home your self with a heat gun and baseball bat
hope this helps
Any why should someone with stock rims and tires have to roll the fenders?
Tony
1998 SVT Contour (B/MB) #542 3L
1998 SVT Contour (SF/MB) #1266 parts car
2000 SVT Contour (SF/MB) #1533 3L swap to begin!
