Now, to calculate your required size MAIN power wire, you need the following:
Wire Gauge? (AWG)
Length of Wire? Feet
Total Amplifier Power? Watts
Amplifier Efficiency? %
Charging System Voltage? Volts
Assuming you are using a class AB amp (50-60% efficiency of power), a steady battery voltage of 13.8V, a wire length of ten feet, and total power at 350W (50-60% eff.) you would have the following:
Resistance/foot: 0.000629 Ohms
Total Resistance: 0.006292 Ohms
Voltage Drop: 0.266 Volts
(well below the accepted half volt drop maximum.)
Current Flow: 42.3 Amps
Circular Mils: 16483 (Keep at > 300 per foot of wire per amp)
Power Drawn From Charging System: 583 Watts total.
check out this calculator.. enter wattages for up to 4 amps, their effeciency, and system voltages, etc.. it calculates everything else.. the yellow text is calculations.
System Design Assistant
