Unplug the speaker connector at the amp, test each speaker with an ohm meter, across each wire pair so you know the speakers are OK. 3-8 ohms, all should match. If you have no meter, an AA battery can be used to "click" the speaker. Do you need a schematic diagram? Did your previous bad speakers sound scratchy and annoying,I have a couple bad ones right now..
