My moms car needs some R134 and i bought it for her at work (Advance Auto Parts) but i forgot to look into the Haynes Manual!!! lol i dont know where the Refrigerant goes into because supposibly theres two spots, one for cold (refrigerant) and one for the heater part. Where is it located to put the R134 in a 98 Dodge Intrepid 2.7L. please hurry since the sun is going down quickly. Any how-to's or hints???
Thanks,
RObert
Mods- SVT Kit, SVT Dual Exhaust, SVT Struts & Eibach's, H.I.D's, CTA Intake, Hightowered headlamps. My 'Tour Car Club- www.HiProfileCc.com
E
E
Try "www.ackits.com"
Go to the forums section,log on someone will help you.
E
E
there are two schrader valves located somewhere along the AC lines.
one is high pressure side and the other is the low pressure side.
the refill kit you bought should come with a hose, right?
it will only fit on to one of the valves.
F
F
www.dodgeintrepid.net Just like Contour.org but for the LH cars.
Start the car and turn the Air Conditioning on when you add the R134A to the low pressure side of the A/c system. That will lower the pressure on the low pressure side. It's good to keep the refrigerant can upright so that the gases are added to the system and not the liquid because the low pressure side of the A/C system has has low pressure gas instead of liquid. The High pressure side has liquid R134A.
yeah, just for future reference, NEVER tap into the high side if the car has the same size fittings (i.e. R12)...
But yeah, you should be good on the R134a... the fittings are different sized, so you can only hook that kit you bought up to the low-side...
Good to go dude!
Goin' Round Traffic Circles @ 50Km/h!!! \m/ -- 1998 E0 SVT #2119 of 6535 \m/ -- 2003 Sentra SE-R Spec V
X
X
Man I dont want to hear about needing AC! brrrrr
Originally posted by Chickens:
Religion can't do much for ashholes (unless you are an alterboy)
98.5 Se w/SVT mods 98 E0 SVT~ sold
Had the a/c going in the work truck today. Was a pretty nice day after the storms in the morning.
