#111256 12/21/01 09:16 PM
Shane Offline OP
I have a 99 SE. How much gains should I expect if I get the SVT Intake Conversion kit from SP motorsports? Ill prolly go with a 80mm MAF,aluminum intake pipe,and a KKM or SHO shop cold air intake.
Thanks
99 SE
Mods in planning.
Audio:
Pioneer DEH-3000 CD player
Mephis coaxles replacing all factory Speakers
2 Orion XTR Pros 15"
2 Orion Xtreme 900s 900w to each 15
1 Orion Xtreme 500.4 powering the Coaxles
#111257 12/22/01 05:24 PM
Shane-
An 80mm maf will most likely be a waste without something to tune the fuel to that much air. Also consider a new y pipe instead. You can only get as much air in as you can get out.
If it's true that we are here to help others, then what exactly are the others here for?
#111258 12/22/01 06:18 PM
E
E
i put on the svt intake manifold with an svt throttle body and a proflow maf,bat pipe and kkm,haven't put it on the dyno but it feels a lil quicker than my bored out duratec intake with svt t\b,when i put that combo on it was a big difference over stock.
97 gsxr lotsa good stuff 4 sale
95 talon tsi awd turbo loaded sold
95 se 2.5 mtx loaded (fragile handle with care)2 motors 3 trannies
custom y with hi flo cat,custom dynomax exhaust,upper cat mod
superchip,udp,bat\kkm,proflow maf,ford 9mm wires,svt throttle body,svt intake manifold ,custom kevlar clutch,16 pd. flywheel,svt motor mounts ,svt gauges,eibachs\h&r,omp strut brace,dark chrome 16" rials with 225/50 dunlops,cwazy amounts of audio
#111259 12/22/01 09:53 PM
cool laugh
#111260 12/23/01 09:34 AM
E
E
thank u mr 3.0
#111261 12/24/01 01:49 AM
Keep in mind that the SVT makes 25 to 30 HP more than the regular V6, and that is with hotter cams and better exhaust so you will not make 25 to 30 HP just from the intake improvements by itself. Even if you make modifications equilivant to the SVT intake and exhaust, you will still lack the hotter cams.
That said, some regular V6 owners have made improvements that get the wheel HP dyno readings up to about the same as the stock SVT readings without the SVT cams. A few mods on the SVT will put it up still more though.
Jim Johnson
98 SVT
#111262 12/24/01 09:37 AM
I did one on a 98se. svt lower,(stock se injectors) svt upper, svt tb,bosch plat.+4s, and injen intake pipe. An educated guess would say 15-20. Very good increase in power and sounds almost like stock svt. The se and my svt will race and try to get a good guess-timate. email @ blegit20@aol.com w/ questions.
18" enkei cdr9 w/ kumho 225/40/18
5% limo all around
alpine head unit
jl xr series door speaks
2 jl w3 w/ppi 2600 and 1 farad cap
b&m
clear head lights
dingless
