#1470460 12/30/05 12:34 AM
machine Offline OP
bought new battery 2 months ago now that it finally is getting cold car won't start ,it just makes a grinding sound as if starter and fly wheel are battling.so i am thinking i need new bendix on starter until father comes over and gives me a jump with his f150 and car starts up fine did this 3 days in a row.battery has been checked and is fine,also it has 590 cca (is this enough?)so should i get a battery upgrade or concentrate on starter and flywheel.
#1470461 12/30/05 05:00 AM
F
F
Replace the starter, hopefully the flywheel is still OK if it hasn't ground too much. Also, make sure the alternator is charging your battery (13.8-14.8 volts) and the posts are clean and tight.
