F
F
Hello,
I have a '96 Ford Contour w/ 66k miles on it. This morning when I started my car I found that I could only recieve heat from the defroster setting. The switch would not allow for heat to be directed torwards the floor, and the high setting for the fan would not work. The other fan settings worked. I browsed the other FAQ's on these forums to see if I could find an answer for my problem but none of them seemed to be applicable. Your advice would be much appreciated. Thanks.
There's a blower motor recall on our cars.
01S22 SEP 01 Recall - Blower Resistor Inspection/Replacement
NHTSA CAMPAIGN ID Number: - 01I009000
Component: - VISIBILITY:DEFROSTER/DEFOGGER SYSTEM:WINDSHIELD:CONTROLS/WIRING
click for recalls
Best bet is to call Ford's 1-800 number and ask customer service if your car still applies for it.
1996 2.5LT V6 Contour ATX My Tour+help/info pics E0 rims, Gutted Pre-Cats,CTA Custom Exhaust & Intake, Diablo Chip.
F
F
You may have the vacuum actuator problem: defrost only and your resistor pack may also have gone bad: blower resistor
