Posts: 1,834 |
hey guys, just wondered if any of you have heard anything about inflating your tires with nitrogen as opposed to plain old air, and if you have, what you think of it. We just got a machine for doing this at the dealership where I work and it sounds interesting enough. I filled up my snows figuring it can't hurt. Supposedly nitrogen is a dryer, more inert, and more stable gas than regular air so it reacts less to temperature changes keeping a more consistant pressure, and also doesn't oxidize the rubber, which helps keep the air from permeating the sidewall. Just looking for thoughts and/or discussion.
Shawn Clone
Jezabel- 1999 SE Sport V6 MTX- Severly wounded, comatose
Silver frost/Black Exterior-Midnight Blue Interior
The Firecracker- 1995 Mystique LS V6 MTX stock and backfiring like a rifle shot
I have 3 loves, my God, Brittany, and my Car.
Posts: 21,653 |
Waste of money, time, everything. No real reason to do it. Air is 70% nitrogen anyways.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 663 |
Originally posted by NorMich99SE: Supposedly nitrogen is a dryer, more inert, and more stable gas than regular air so it reacts less to temperature changes keeping a more consistant pressure, and also doesn't oxidize the rubber, which helps keep the air from permeating the sidewall.
Looks like you answered your own question.
I go to UTI in phoenix right now, and in my undercar class(steering, susp., wheels, and tires.) we watched a video that said air will just about be obsolete in like ten years, that the nitrogen is so much better. It also said that alot of trucks have been using it for the past couple years.
Keith P.
Killed in action-4/27/06
'99 CSVT
#2369/2760-7/28/99
New Recruit-
1998 EO CSVT
# soon to come
Black 106,xxx
Posts: 4,693 |
It is real common in race cars and I understand that all airliners use notrogen only.
Personally, I'm not having enough trouble with ordinary air to motivate me to spend extra money for nitrogen. Very interesting concept though.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 21,653 |
I'm thinking bout using helium. Think about it. Weight reduction.
98.5 SVT
Posts: 316 |
It's about as good as completely dry air in terms of performance (resistance to pressure increase with heat).
It's the water in air that causes it to expand with heat. Most air pumps have some moisture in the air. That's what causes the pressure to rise when the tire heats up. Ideally, you don't want the temperature to decrease at all.
Another nice thing is nitrogen escapes from tires slower than normal air (bigger molecules). This means you need to check it more often.
If you want to try it, go to your local Costco. Most have switched over to nitrogen. It's free. Deflate your tires as much as possible, refill, repeat.
Posts: 1,834 |
We have a machine at work, and I already filled mine up for free. I thought it was kinda cool myself.
Shawn Clone
Posts: 1,423 |
Some of the higher end racing wheels have dual valves for replacing the air with nitrgen at the track. The dual valves make it easier to pump the nitrgen in one valve while forcing the air out the other or so i have been told. example these are on my sons highly modded A4...Kosi Racing K1 TS
Scott
2000 Contour SVT #1464
Mustang Dyno: 171.6hp/145.3lb
Dynojet Dyno: 171.1hp/148.9lb
1989 20th Anniversary Turbo T/A "Indy 500 Pace Car"
#1376 of 1550 All Original, 46k with a few mods
2002 F150 SuperCrew
Posts: 1,176 |
Purchase tires with see through sidewalls.
Embed sidewall with tungstan filament and attach to battery
Fill tire with nitrogen
Now you have the ultimate light bulb!
Bob
Posts: 3,816 |
Bob
Sweet! But as soon as you do it, EVERYONE's mom is going to have it on their Escalade.
