Posts: 1,651 |
K here it is i left today from my house. i go to leave first gear and i hear a clunking about 4 clunks as i am releasing the clutch and as i intially am moving after i am moving it stops clunking. Then when i shift into second gear i hear a clunk clunk then it goes away for any other gear. So i notice it has happend for every start. I think it is a diff or motor mount? something in that nature comes to mind?? No shakiness or hesitation or slippage. What do u guys think.
I reject your reality and substitute my own.
Posts: 536 |
when I lost my diff, I noticed no noise at first. Aafter about ten miles, A loud Super charger type whiring sound, and it was toast. Dont know, but good luck.
99' SVT #811 of 2760
Born on january, 12, 1999.
"This may have been his only shot at number one, but he just sucks on so many levels that I couldnā??t even let him win a contest of suckiness."
Posts: 177 |
I had what sounds like the same thing going on and it was the motor mounts. Jack it up and look at them.
98 Tropic Green Contour 2.5 MTX
Posts: 1,651 |
I checked out the mounts today and found nothing wrong with them. took it to the car was maybe some frozen ice or something, which wasn't but i havn't washed my car all winter so far.
It has gotton worse, it sounds like a snaping more than a clunking, like snap snap snap more and more. Maybe the axles are about to break in half!!
Posts: 1,456 |
It could be, or a cv joint has failed.
Posts: 82 |
Get a pan and dump the tranny oil. A clean pan. Assuming brass synchos there may be a very light tinge of brass in the bottom of the pan. If there's anything else take a look at your bank acct. Otherwise shake the axles fore and aft. Might just be a joint. Might be the right side axle carrier bearing.
95 Contour, 2.0L, stick, 178K mi.
Posts: 10,015 |
Is the tranny resting on the subframe on the drivers side? It should be sitting an inch above it.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 1,651 |
it isn't resting on the subframe.i thought that also, they had to adjust the position of the mounting they told me before when they put back my trans.
I am out of ideas. It does no make the noise when i am in neutral rolling front or back and me reving on it. This is where i assumed it was teh trans bouncing off the frame, so i did those tests!!.
I keep thinking the axles for some reason, maybe lose??
I am lost on this. i can't seem to trace the prob.
hmmm
Posts: 1,651 |
Ok i have to admit i found what was wrong.
When i decided to take the car to the dealship i took off the my omp bar and my air intake. Just incase i don't void anything. Well taking off my omp bar i close teh hood and then leave. Guess what???
NO noise.
It was the omp bar lifting and the noise was coming from the 1 screw poping in and out. Man that thing was loud. I thought for sure it was my car about to explode, well i was hoping!!
Well i am going to buy a larger screw for one hole and fix the problem. What a scare!!
For for all the help guys!!!
Posts: 82 |
Thanks for the followup.
I've got to look into a bar of some sort myself.
