Page 2 of 4 1 2 3 4
And this is for pushing out the shaft from the hub:
FWD Axle Shaft Puller
sur4die Offline OP
right, i saw that on the 'zone page too.
i'm still kicking myself over this... at least i have a story for christmas now.
Keep that one to yourself.
sur4die Offline OP
Originally posted by tour96se:
you can pick up a remanu. for like 40 dollars.
Where? every place i have been looking it's about 80.
Yeah $40 is a pipe dream - plus do you REALLY trust a $40 reman axle when all the rest are $80+
sur4die Offline OP
hey, you never know. i thought maybe there was some forum source where you give the secret handshake and can get it at a significant discount...
to get the outer stub shaft out of the hub you have two options. Put the hub in a vice and use an air hammer to push the shaft out - NOT A SLEDGE, YOU WILL RUIN THE BEARINGS! Or the best method. Rent a driveshaft puller/pusher from Murray's/local auto parts store chain and push it out.
I figured after my axle still wouldnt come out after using a 20 ton press, it was a lost cause.
Wonder if PB would work it's way in... sounds pretty rusted in.. you did take the axle nut off (not trying to be an a$$)
JD a.k.a Fingers "Don't Panic" '98 Contour GL 2.0L VCT ATX 88k '98 Contour LX 2.5L MTX 120k Street racing can kill just less of a chance with a 2.0
9
...nope not a pipe dream...if i had a scanner...i should've been clearer i can order them,,and i have for 40..thats what my shop gets them for..so that means,thats what i get them for..and yes its held up to ALOT of beating since the new engine went in...my crazy ass tuner had no idea what wheelhop could do to this car..
9
the name of the parts store i ordered it from was united auto supply,out of binghamton new york
Page 2 of 4 1 2 3 4
