#1466325 12/21/05 09:38 PM
My svt has grown increasingly louder in the last few months, and i now realize i have an exhaust leak. When warming up the car in the cold, all the smoke comes from underneath the car instead of from the exhuast tips.
I think i've pinpointed the location, but it would really help if someone could post a picture of an SVT exhaust, that way i can get a precise description to you guys to see how to fix it. I believe its close behind the cat.
Searching for SVT exhuasts just gave me a bunch of aftermarket pics...
98 SVT #1652 of 6535 My SVT "If everything seems to be going well, you obviously don't know what the hell is going on."
#1466326 12/21/05 09:59 PM
From my experience, common leaks on our cars are right after the primary catalytic converter. More than likely, it's only your gasket.
Go back out, and run the car. Find some old cardboard and place it under the culprit leak spot(s). Get back in and revv the engine, but not too high if it's cold still..
this should find your leak as black soot will cover a spot on your cardboard.
Unfortunately I can't supply my pics as I've locked my backup CDs into a fireproof box that is currently buried with stuff
#1466327 12/21/05 10:03 PM
i tried filling a spray bottle with soapy water. I sprayed it over the areas, and its bubbling and shooting out where two sections of piping are connected, after the cat. Im guessing theres a gasket in there?
#1466328 12/21/05 10:14 PM
So the leak is bubbling between the cat and the pipe it connects to?
If so, that is a DIY fix for no more than $5 (gasket) The rest of the exhaust system (past the cat) is welded together and would otherwise have a hole or two if it were leaking like that.
Anyone have pics for this guy?
#1466329 12/22/05 05:05 AM
ok, if no one has pics, does anyone have the part number for the gasket?
#1466330 12/22/05 05:14 AM
It could also be the flex pipe. Mine kinda did the same thing.
[color:"green"]-Matt R
'99 Tropic Green LX, Zetec, ATX
#1466331 12/22/05 09:25 PM
i also have exhaust 'smoke' coming out places other than the rear. mainly under drivers side (exits by drivers door)
is that where this gasket would go? could save me some work/$ if its the case. thanks and good luck on your fix
- 98 SVT #5999 -. -CDA-7894 w/ ipod interface -Knauberized, Trubendz 2.5/highflow cat
#1466332 12/23/05 12:50 AM
mine is mainly coming from the passenger side, i think. Im pretty sure its the gasket, id recommend trying what i did and spray some soapy water on it to see where its coming from
