Posts: 536 |
Will a spun rod bearing ALLWAYS give a cel? Thanks
99' SVT #811 of 2760
Born on january, 12, 1999.
"This may have been his only shot at number one, but he just sucks on so many levels that I couldnā??t even let him win a contest of suckiness."
Posts: 10,015 |
Eventually it will but not at first.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 536 |
thanks. I have had this noise for about three weeks(less than 15 mi/wk), just got a cel, p1518, working on that, shouldent the knock sensor have come on then?
Posts: 10,015 |
If it's a knocking that sounds like a womans high heels on a wooden floor, and it varies with speed, you can almost guarantee it's a fuxored rod bearing. It's usually accompnied by a burning oil smell too.
AUSSIE ENDLINKS $70
Posts: 536 |
I have allready had one bearing, this is a faint ticking mainly on acceleration. With or with out load, starts at 2500rpm's, dies at top end, dies at low end. I am less woried about this now. New noise appeared last night, louder, roughr clanking. Only occurs with load, when you let off the gas. It goes away as soon as you give it the slightest amont of gas with load. This is a new one to me. Dont know if it helps, but with the ticking, it is not any louder when the oil cap is removed.
Posts: 31 |
I still have a weird ticking noise that appears at first startup. I've been concerned that it could be a bearing as well, but it goes away once the car is driven and warmed up. Not sure what the hell it is. Noone else has described this problem. It's always the same speed, doesn't vary, and goes away when the RPMs are increased. It's like a "tack-tack-tack-tack-tack" noise coming from the passenger side of the motor. 97 Zetec.
Posts: 536 |
hey, thanks for the hijack homie.
Posts: 1,456 |
For Zetec: Bad lifter. Try better oil (sythetic), may help some.
Posts: 10,015 |
Originally posted by Kyler: I still have a weird ticking noise that appears at first startup. I've been concerned that it could be a bearing as well, but it goes away once the car is driven and warmed up. Not sure what the hell it is. Noone else has described this problem. It's always the same speed, doesn't vary, and goes away when the RPMs are increased. It's like a "tack-tack-tack-tack-tack" noise coming from the passenger side of the motor. 97 Zetec.
Before your next oil change use some engine flush and FOLLOW THE INSTRUCTIONS. Then refill with QUALITY synthetic oil not the cheapo crap. You probably have gummed up lifters from using cheap oil.
AUSSIE ENDLINKS $70
Posts: 604 |
is p1518 not the imrc box stuck open???
G/f's black 99se sport 5 speed
2 1/2 test pipe-custom cat back 3 single tip
cai with kn3530
safc optimized tb
8mm plug wires
spec stage 1 clutch
svt front bumper
