Posts: 536 |
Ok finaly got an engine light. Again. I searched and took a look at my car. The linkage seems to be disconected. Again. It feals like I have great power from idle to 3k, thats all the higher I have been taking it. Thats were the ticking or rattle starts, could they be related? That would be nice.
99' SVT #811 of 2760
Born on january, 12, 1999.
"This may have been his only shot at number one, but he just sucks on so many levels that I couldnā??t even let him win a contest of suckiness."
Posts: 2,408 |
You may want to fix the IMRC but it's not causing the rattle.
Partially blocked EGR and cylinder carbon buildup are usually the culprits. A lean mixture will make it worse, as will bad or wrong plugs. If it's really inconsistant make sure the plug wires are not leaking and crossfiring.
Posts: 1,456 |
Just recently,someone else had knocks, see this topic plugs Bad plug, very bad. New plugs and ignition wires may be needed (Autolite APP764 plugs.)
Posts: 536 |
ok, so last night on my way home from work(2mi), a new noise devolped. when there is a load on the engine and you let off the gas, a much louder kluncking comes about only until you push on the gas again. I get paid on the 2nd(I hope) then she will go in so a mechanic can tell me the engine is trash. anyone who can shed some light on this newest noise would be my hero.
edit: how would plugs/wires make noises like this?
Posts: 1,456 |
It probably wouldn't when the load it off. The engine knock without load, is the oil pressure light on?
Posts: 536 |
nope, no oil light, it has been leaking(for the first time), but I have been all over it, and it is not low. Could low or too much oil cause my latest noise concern?
edit: The thing I dont get, is it is still smoth as ever. When knocking or not, low or high. also, code says imrc stuck open, but I have great low ind, but the high end is noticibly not there.
Posts: 1,456 |
Maybe the knock is not internal to the engine. Some accesory idler, a/c pulley, catalytic shield?
Posts: 536 |
would that fit all these peramiters? I looked at the heat shield's, looked fine. How can I tell if it is an accy? I am going to cry. I hate this sooooo bad. F*** being poor.
Posts: 10,015 |
P1518 is IMRC is stuck open
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
