Subject vehicle is a '95 w/ Zetec and automatic. Everything works fine, but the shifter feels like I'm moving it through molassas when I go to shift it. I suspect something just needs a shot of some spray silicone - no idea whether I should be looking to do this from the inside or under the car - any suggestions?
Alternatively, I suppose it could be that something fell into the shifter slot and is binding and the handle goes back and fourth? Just guessing here - help me guess better!
Brad
2
The tape that slides back and forth and moves the indicator is probably ready to snap off. If it's still in the track try some silicone.
F
F
Or, the cable underneath the car under the shifter,needs lube.
Probably best to take the trim surround off so as to get better access, yes? I haven't even looked yet, but I'm assumming that won't be too difficult.
Does this cable ride in a sleeve? If so, any idea where the best place might be to get access to the sleeve-end where I could squirt some lube in?
F
F
From underneath the car, under the shifter. There is a sleeve over it. (I have never done it (yet, the day will come!), but some CEG'ers have).
