First, as I have discovered here the '95 Contiques had cheap (I'm suprised
) instrument panel facias. But I seem to recall mention of the '96 and up instrument facias are a better quality. Mine is crap. A previous owner removed the outer plastic on the center vents and all but one hole that holds the facia to the dash are broke, so it just kinda sits there. So, if the '96 and up are better are the mounting holes the same? Also, since I have traction control do I have to get a facia with the traction control hole or is it a removeable blank? Second, being that I have a Mystique which has the rear dome light I am wondering if the dome light is suppose to go on when the doors are opened? Mine doesn't. It works when the switch is moved to the always on position, tho. Third, the passenger front door handle light is out. Is that fixable??
Later. Pepse.
