Posts: 35 |
Happy Holidays everyone. Every since it has been getting cold I have been encountering some electrical problems when I go to start up my car. When I turn my key to turn on my accessories I don�t get anything and I can�t turn my car on, where I would normally have power. Sometimes I will get power, and then when I turn the key to turn the car on it goes dead with no power. After I do it several times I will get it to work and the car will turn on. Any ideas? Starter..Starter relay�ignition switch�
98 Contour SVT:
MUSTANG: 87 GT 5.0: TFS Twisted Wedge heads, TFS 1.6 Roller Rockers, Cobra 5.0 Intake, 3.73 gears, 76mm C&L MAF, JBA Headers, Moroso CAI, Steeda Tri-Ax Shifter
Posts: 35 |
98 Contour SVT:
Posts: 1,456 |
Could be the ignition switch is worn. How's the battery, and if the car starts, check the voltage at the battery is 14 volts or more.
Posts: 1,788 |
Your ignition switch is worn out.
Steve
89 Taurus SHO - 246K miles
94 SHO ATX - 190K
Posts: 284 |
that would be my guess also as you describe that you would have to work the key to get the power to come on.
Posts: 35 |
Is the igntion switch hard to swap out?
98 Contour SVT:
Posts: 1,788 |
Originally posted by fiveoh: Is the igntion switch hard to swap out?
No. Here are the instructions fromthe Service CD:
Ignition Switch
Removal
1. Disconnect the battery ground cable.
2. Remove the steering column lower shroud. *Remove the three screws.
3. Remove the ignition switch. *Disconnect the electrical connector. *Remove the two screws.
Installation
1. To install, reverse the removal procedure.
94 SHO ATX - 190K
