Posts: 291 |
What is the consensus on camshaft useage for a 3.0? Has anyone had any experience with aftermarket (non-Ford) camshafts? As I recall, B Noon ran a 3.0 cam on the exhausts and something else on the intakes.
Redcoat Raceworks. Performance parts and custom fabricating for Contours, Mystiques and Cougars. Specializing in chassis and suspension parts. Custom end links, control arms, strut tower bars, engine torque braces, etc.
Posts: 10,015 |
Depends on your application - but my preference is SVT cams all the way.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 2,974 |
I'm guessing a 3L Escape motor with CAT Cams  . I must say these are looking to be a huge pain in the arse and may just have to ditch the bloody things. I was told by a performance shop to just put the cams in the car then go to the dealership and have them put the cam gears on and use a degreeing(IIRC) tool to time it. Aaron
AKA NVS SVT
98.5 Silver/Blue SVT#4553
Yeah it's modded
98 T-Red/Blue SVT Contour Totaled 06/05/06
03 3L,VCN 2000,CAT Cams,MSDS Headers w/Y-Pipe,XCal2 and lots more
Posts: 1,746 |
Use the SVT cams. Easy swap, and proven good.
2000 Contour SVT
SF - #542 of 2150
Posts: 4,693 |
Originally posted by NVS SVT: I'm guessing a 3L Escape motor with CAT Cams . I must say these are looking to be a huge pain in the arse and may just have to ditch the bloody things. I was told by a performance shop to just put the cams in the car then go to the dealership and have them put the cam gears on and use a degreeing(IIRC) tool to time it.
Aaron
You're not likely to find a technician in a Ford dealership that knows how to use a degree wheel. More likely in a high performance engine rebuilding shop. Possibly in a Porsche or VW shop depending on how many years ago they went thru training.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 2,974 |
Originally posted by Big Jim: Originally posted by NVS SVT: I'm guessing a 3L Escape motor with CAT Cams . I must say these are looking to be a huge pain in the arse and may just have to ditch the bloody things. I was told by a performance shop to just put the cams in the car then go to the dealership and have them put the cam gears on and use a degreeing(IIRC) tool to time it.
Aaron
LOL thats not what I wanted to hear thank you for bursting my bubble , damn these CAT Cams.
Aaron
AKA NVS SVT
Yeah it's modded
Posts: 9,602 |
Originally posted by Bradness: What is the consensus on camshaft useage for a 3.0? Has anyone had any experience with aftermarket (non-Ford) camshafts? As I recall, B Noon ran a 3.0 cam on the exhausts and something else on the intakes.
All "regular" split port cams are the same. (2.5L or 3L) The only different split port cams is the SVT set.
All oval port cams are the same.
The Mazda 6 exhaust cam is usable.
All the above specs are known. All cams have the same lift.
Other then that there is CAT cams. They have a nice selection of cam profiles. The main issue with them is they don't come with cam gears.
If I were to pick a set of CAT cams I would go with the Stage 3. If mixed then Stage 3 Intake and Stage 2 exhaust. Specs are on their site.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 1,101 |
Aaron
Let me know if you eventually decide to go another way with these. I could give these a good home.
Posts: 2,974 |
Originally posted by timeless420: Originally posted by NVS SVT: I'm guessing a 3L Escape motor with CAT Cams . I must say these are looking to be a huge pain in the arse and may just have to ditch the bloody things. I was told by a performance shop to just put the cams in the car then go to the dealership and have them put the cam gears on and use a degreeing(IIRC) tool to time it.
Aaron
Evan I will let you know if I decide to let the CAT Cams go.
Aaron
AKA NVS SVT
Yeah it's modded
Posts: 291 |
Evan: If you end up with the CAT cams then I have first dibs on your SVT cams.
Deal?
