It appears that the head gasket for the 3L block (I'm using the 04 Escape block with 3L PnP heads) blocks off four potential coolant passage areas per side. The passages in question are one each on the intake side and flywheel side on cylinder 3 and one each on the exhaust side and accessory side of cylinder 1. This is mirrored on #6 and #4 on the right hand side.
Is there any reason for this? Not that I'm eager to out-engineer a degreed Ford engineer and go wantonly punching holes in a head gasket, but ideas would be appreciated as to why this is so.
So far I've picked the brains of todras and Buckshot, but both of them don't have answers either.
