Posts: 157 |
i have a 98 svt a would like to know what 1/4 times to look for a try to hit. I have 19'' rims intake exhuast..
98csvt(red)white 19''Axis se7ens on toyo 225/35/19's injen intake,cust exhaust, High Rev's racing clutch,and flywheel .whatever its takes to run 12's (system)Eclipse 5442,Boston 6 1/2" pros, Eclipse 5x7 point scourse,PPIpc4400,PPIpc2600(chrome),power cap,2 12"JLW6 YOU WILL RESPECT THE FAMILY CAR
Posts: 2,156 |
depending how much your 19" rims weigh. you should be hitten around 15.5's stock. i ran a 15.3 @ 90MPH with just KKM intake on my '98 SVT. so i am guessing on an average of 15.5's.
Sam 1998 Contour SVT #180 1/4=14.2 @ 101.17MPH
AOL users = PhatSVT _ _ _____________ _ _
1986 Mustang GT 12 second club
Posts: 301 |
Ford says the SVT can do a 15.7@88mp 1/4 mile. My best run is 15.684@88.41mph. I've got a 100% stock 98.5 SVT and run at Route 66 Raceway in Joliet, IL.
I get 2.3-2.5 second 60foot times and hit 4th just before the lights. No power shifting (in other words I use the clutch to shift) and I drop the clutch around 3,300rpm.
3rd gear sucks, as it takes FOREVER thru 3rd. I need more power!
19" rims will slow you down, assuming extra weight and larger diameter tires.
Posts: 3,419 |
Dont you just hate how 3rd gear gets you this {} close to the timing lights, but not quite there and a little too far to bump the rev limiter the rest of the way? I can't wait to run with my short shifter.
Posts: 301 |
Yes I do hate that.
We can get a chip to raise the limiter, but after reading the 'oil starvation' thread, I'll keep my 7k cutoff thank you.
Posts: 424 |
MYSVT98 FYI:My last trip to the strip was my first time since I had gotten my Diablosport chip w/7,500 rev limiter. I wasn't sure if I could make it through the traps in third, but I tried resulting in a couple bounces off the limiter, a gear change to fourth, and a 15.27/91.59mph run. I'm running 215/45/17 tires also. So without final drive ratio mods, or even taller tires, there's no way(for me anyways) to make it through the traps in third.
2000 SVT silver/blue #1699 of 2150 14.793@94.88 Sho-Shop off road y-pipe for sale($75)
Posts: 1,367 |
I ran a 15.5 at the track a few weeks ago. It's the first time I ever raced, it was very cool to say the least! My only mod is a KKM intake. Unfortunately I had 3/4 tank of gas in my car also. Spare and jack were also in trunk still. I'm curious to see what I can run on a low tank and empty trunk!
Posts: 592 |
Stock w/just B&M - K&N 15.49 @ 88
Ryan 98.5 Silver Frost Tour SVT 5979/6535 Born: May 15, 1998 Some Mods, still not fast enough.. 90 Black SHO
SVT Performance.Com
Posts: 1,022 |
Not stock 3.0 with shifting at 4500rpm because lack of fuel to engine 15.48 @ 92, 0-60 7.4secs I made the 1/4 mile in number 5 gear because of such a low rpm shift and I made the 0-60 in 4th. I cant wait to see when i can bring it to the 7k it wants to go to. I am estimating very low 14's. even with 4500rpm shifts, I still beat alot of cars around here. hehehehe
Micah
97 Lx 3.0 MTX lighten flywheel,udp's,kkm,no cat,true dual,svt tb,80mm maf,19lb injectors,S-afc,svt ground effects, 18's w/ yoko 215/40/18,front/rear strut braces,eibachs,egr gasket mod,
15.2@94 with 2 people in the car and a bad 1st gear wanna race?
micah_trudell@hotmail.com
Posts: 130 |
with mods listed below... i ran a 15.216.. hehe rite now i currently have the quickest NON BOOSTED ga on out forum... NOS guys are running 14.4's and the SC guys... who knows they are still messing with them
99 Grand Am GT ower LOVE FORDS THO! GO SVT seriously! MAF mod, B&M Shift Kit (no manual trans.) Lexan Intake 7" cone, Next.... Borla Exhuast, ASE Chip Reprogram. Suspension mods next summer  Just WON Ram Air Hood and Spolier! BEST TIME: Norwalk Ohio 15.216@88mph Also painted "Metal Flake Blue" interior SHARP lookin! *NEW* AED Rear Facia, Lotek Pillar guage Pod and guages!
