Posts: 37 |
I searched for the update to the alternator wiring fix, for power to the voltage regulator, but I cant find it. My alt test good, but puts out no voltage in the car....
--Craig
Angel - 1997 Ford TBird (BHG for now) 4.6 SOHC
Gwen - 1996 Ford Contour 2.5 DOHC
Posts: 5,345 |
1996 V6 ATX 96K miles
Posts: 1,456 |
Posts: 37 |
I checked the megafuse, it was good, the problem was that the wire to the reference voltage on the alt was broken. All better, car still has tranny issues.
--Craig
Posts: 4,639 |
is the megafuse just like a regular fuse u check? i wanted to check it but couldnt get the black case open when i was messing with it.
Hugo AIM:omegazodiac
Posts: 37 |
Hammer....
Seriously, I had to break it to get in there.
--Craig
Posts: 1,456 |
Check with ohm meter from output post on alternator to starter, starter to battery. If you can reach the alternator  Should be the same ohms as touching the meter probes together.
Posts: 4,639 |
Originally posted by FavoriteMystaque: Check with ohm meter from output post on alternator to starter, starter to battery. If you can reach the alternator Should be the same ohms as touching the meter probes together.
i didnt see any damn way to reach the test points on the alt before i removed it. its so far up there. barely got my small hands in there to get the bolts out after breaking them loose.
Posts: 1,456 |
Did you find your problem?
